Product Description
P3 Digital gauges provide the highest level of OEM integration and color match offering more features than any other gauges in their segment. Starting at a price competitive to single feature old-school needle gauges, they offer unmatched feature to price ratio.
All gauge models include an on-the-fly configuration menu for setting units (BAR/PSI for boost, and C/F MPH/KPH for multi-gauge values), as well as feature options, and ambient calibration. See www.p3cars.com/install for more details.
P3 Boost Gauge
  • Boost and Vacuum with integrated 35psi sensor.
  • Battery Voltage readings with quick-look and sleep-check.
  • Optional Auto-Dim or Manual Dimmer
  • Includes Digital Display, AuxBox w/Sensor, Vac Tubing, Wiring, Wire-taps, Zip-Ties
P3 MULTI-GAUGE
  • Boost and Vacuum from OBD2 port
  • Plug and Play install - just plug into your obd2 port and install into dash!
  • Optional analog sensor for reading boost on tuned/big turbo cars.
  • OBD2 Data for Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
  • Code Read/Clear
  • 2 x universal 0-5v linear analog inputs
  • Includes Digital Display, Custom OBD Wire Harness, Control Box.
Produto semi-novo em perfeito estado.
Valor dele novo é de 389.00 Dólares + 54.00 de frete + impostos.
acho justo R$: 1.100,00 pelo produto.
mk7_1.jpg?v=1463670329
