Thursday,16,September,2021,22:37:32:00233
VCDS Version: Release 21.3.0 (x64) Running on Windows 8 x64
www.Ross-Tech.com
                Address 17: Instruments       Labels: 5G0-920-XXX-17.clb-SRI3
Control Module Part Number: 5G0 920 861     HW: 5G0 920 861
  Component and/or Version: KOMBI         204 3390
           Software Coding: 07A519182380000800086A00040000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_DashBoardJCIMQBAB 008011 (VW37)
                       ROD: EV_DashBoardJCIMQBAB_008.rod
                      VCID: 66C9EB5A996724BB59-8032
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [009] - Internal electronic failure
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Date: 2000.00.00
                    Time: 00:00:00
alguem já conseguiu resolver esse b.o. ?? socorro kkkk    ja fiz tudo limpei ta tudo ok, nao da falha...  Tenho cabo vcds e programa ...  se alguem tiver alguma ideia ou algo me bipa ai  vlw ! abrçs
  • 7 months later...
