Boa noite galera estou com alguns erros no meu carro, conhecem algum site que decifra os códigos do VCDS? Estou com a versão 22.10
Address 02: Auto Trans (J743)
1 Fault Found:
10693 - Clutch 1 Opens Unintentionally
          P175D 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 0
                    Fault Frequency: 112
                    Mileage: 74007 km
                    Date: 2023.06.14
                    Time: 08:16:31
                    Engine RPM: 14655.75 /min
                    Engine torque: 920 Nm
                    Vehicle speed: 255 km/h
                    Control Module temperature: 215 °C
                    CURRENT pressure: 20.5 bar
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator pedal position: 100.0 %
                    DTC memory status: 65280
1 Fault Found:
10577 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 16
                    Mileage: 74009 km
                    Date: 2023.06.14
                    Time: 20:33:22
                    Engine RPM: 976.50 /min
                    Normed load value: 23.9 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 35 °C
                    Intake air temperature: 20 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 14.489 V
                    Unlearning counter according OBD: 39
                    Mass flow through throttle valve: 9.6 kg/h
                    Mean injection time: 1.133 ms
                    Engine operating condition: Idle
                    Engine operating condition-Test_Program_Channel 87: 5
Readiness: 0000 0000
